Newbie questions - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-12-2009, 05:11 PM Thread Starter
Newbie questions
I think this is the place to put this thread.....if not a mod can please direct me to the right spot.
I am in the market for a 99+ 7.3l SD.....I've found a few that I'm going to be looking at early next week. My question is what are the huge things I should be looking for?
Are the frames weak in any spots? if I'm buying in a high rust risk area, is there any frame rusting I should be worried about? or are the frames pretty stout against surface rust?
I know the general getting an idea for recent maintenance and history. I'm just looking for this generation SD specific things I should look for.
Thanks!
Ryan
WSUFlyer is offline
post #2 of 5 Old 12-12-2009, 10:56 PM
layson's Avatar
Quoted: 82 Post(s)
Are you up in Washington.... check out Northwest Ford Diesels there are a lot of local guys up in your area that can help you out.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #3 of 5 Old 12-13-2009, 06:43 AM
Powerstroke Junkie
NCHornet's Avatar
Here you go
http://www.powerstroke.org/forum/7-3...99-03-psd.html
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #4 of 5 Old 12-13-2009, 06:58 AM Thread Starter
Originally Posted by NCHornet View Post
+1 THANK YOU! Hopefully I'll have a truck to post pics of in a couple weeks as I become part of the POWERSTROKE nation!
WSUFlyer is offline
post #5 of 5 Old 12-13-2009, 03:48 PM
Powerstroke Junkie
NCHornet's Avatar
That's a different diesel forum we are THE ORG.!!! Just kidding and good luck any ? just PM me.
NCH
NCH
Ford AIS/ BTM, FTVB
KMC Wheels x 4
NCHornet is offline
