Ok, a question for the Pros'
I need to pull my motor to replace my rusted oil pan on my 2002 F350 7.3. I'm sure you herd it all before, being is a common problem with the 7.3. Anyway, while I got the engine out I'm gonna change out the Up Pipes and replace the front and rear main seals. I bought the Fel-Pro Conversion kit that includes these seals, but Im not sure if I should buy the Ford OEM or use the Fel-pro's that came in the kit. I don't want too do all this work just to have the fel-pro's leak. Are the Fel-pro's better than the Ford OEM, or are the OEMs better? Also, anyone know where I can get a set of Up-Pipes for a good price. Thanks in advanced for your comments Al |
as far as the gaskets i am not sure, but for the up pipes, i would do the bellows style conversion.
Ford 7.3L Powerstroke Bellowed Turbo Up-Pipes Bellow |
Diesel Innovations offers the up-pipes in ceramic coating as well as normal bellowed pipes..... Everything Ive used fel pros for they have been better than OEM but I have not used them on my stroke yet.... This is muscle car and import stuff I used them for, always worked and looked alot better than oem gaskets tho...
First of all how many rear mains leak on a 7.3? Not many, if it isn't leaking I would leave them alone, I have seen 500k+ trucks with stock seals still tight. As for the up pipes the bellowed kit is the only ones I would consider.
NCH |
Rear main leak
I have a leak coming from some where in back of the motor. I have already checked the torbo pedistal, the hpop and there is no oil in or around the top of the motor. I don't know where else it could be coming from.
Any ideas? Thanks, Al |
I am not saying it is impossible just not common. I would make sure you clean the area real good and be sure where it was coming from, 98% of the rear mains replaced are done because something was leaking higher up.
NCH |
