Tranny Question
thinking of doing the 24v swap in to the Ex.
i currently have the 4r100 trans and when i do the swap im going to be using the 5r110 torq shift. question is... will the 5r110 bolt up to my 4wd transfer case that is currently married to the 4r100 or is the bolt pattern different between these two. ![]() Thanks Fellas |
I doubt it, why not use the transfer case that belongs on the Torque Shift?
NCH |
do some research, thers a company ( I forget the name ) that makes the adapters...also one for the harnesses......
thanks |
If your swaping the engine I wouldn't use the 5r110 get a BTS 4r100 you will be glad you did.
www.destroked.com has alot of stuff
i thought the 5r110 was the "best" ford tranny out there
And if you do, he is going to fix it, no questions asked. You break the 5r100 from Ford and it is going to cost you...
guess it the BTS 4R100. thanks for the help fellas.
