Transmission Temps
What temp do you see your transmission reach when daily driving normal and under high throttle ect...
Mine barely leaves the 0 mark if at all and stays around a 100. I never see it go high at all. Is that because I'm not towing? I'm sure it will increase in the summer but even when I hammer down it does raise much at all. Just trying to see if everything is working ok and what not. |
The Search button is amazing for info like this!!!
Normal trans temps are 70-90 above ambient. The lesser when not towing and the greater when towing heavy. My temp gauge won't move until spring!! NCH |
Yes it is when you have the time to spend to search, in my case I don't. Thanks for the information.
Is there a temp it should not reach? |
you wanna stay under 200ish
I wouldn't think you'd wanna be too high, not sure why they make the gauge read so high.
Sustained temps above 200 means you need more cooling, 210-220 is when I would be pulling over.
So you don't have time to use the search feature, but I have time to type the same replies several times a week???? How does that work???? Just picking at ya, but the search feature will be a lot faster than making new threads as a lot of this has been discussed in great depth already. See ya NCH |
Much appreciated.
I've been getting trans temps from 160-190 lately just driving city/highway not towing. I am going to order a frame rail mounted additional cooler with fan with thermostat with tons of flow. 400 cfm i think it said. Also going to try to install a trans go shift kit to help as well.
made this just for all of you! lol ..about a month ago.. 160-190 is normal..youll be fine..when i tow i see 180-195.. im going to be adding another cooler soon.. |
Sounds like you need a 6.0 trans cooler. I usually see 60 above what the temp is outside empty and about 80 above when pulling my 5er. The 6.0 cooler is massive!
