A few general questions...
Hi!
Well, here's an issue I get... At around 1500rpm and part throttle I get a surging, but without the trailer. Is this the same turbo surge ya'll have talked about? Also, I'm pretty handy with the SI motors (I've got a TA I've built that should run mid 11's on the new set-up), but I've never had much CI or FI experience. I'm trying to make the beepbeepbeepbeep thing as efficient as I can so I can save some money on fuel as it's my daily driver... So far I put a B&S airbox on it and it seems that's helping considerable (hard to tell, I keep leaning into the right foot more now just to hear the turbo spool and the airbox suck the air as it does, haha), but I tend to shift at 1500rpms to keep fuel consumption lower. So far I tend to get around 20mpg bone stock with mixed highway/city on a stock set-up. I haven't run a tank through with the air box yet to see any mpg gains on that guy. I want to run a turbo-back exhaust to help in that realm, but I know in the naturally aspirated world that as you open up the exhaust torque peaks shift higher in the rpm band. That's great and all, but I want to be driving around my torque peak so it takes less pedal to maintain my normal level of acceleration for less fuel burn. Would stepping up to a 4" system raise my torque peak and make for a slushier bottom-end or would it help the turbo spool faster and make for a torquier bottom-end? Thanks! |
With the turbo diesel, you will find that opening up the intake and exhaust will give you better low and mid range torque. I have the AFE stage 2, and 4'' turbo back Magnaflow duals . When I put them on at the same time, it woke up the bottom end nicely, the DP F 5 chip turned it into a screamer. As far as the surge goes, it's usually noticeable when pulling a load more than empty. What you have could be a problem with the fuel injectors, perhaps 1 not quite up to snuff. But I am not a tech, just going by my experiences.
Gord. |
I was hoping it wasn't injectors, haha
I was thinking about getting some new injectors and sending them off to Dynomite Diesel Performance to get them extrude honed and balanced. I know they're not a sponsor but I saw their ad in Diesel World... are there any sponsors that perform that mod? Would it be worth it for fuel mileage/power/reliability? I had my injectors flow-matched for my LS1 and that really balanced out the afr helping keep me from running a lean bank/cylinder, but then again that's not as important in the diesel world as there's no such thing as detonation, hahaha Thanks again for any and all help! |
If you look on the home page of the forum, you will find a blurb stating that Dynomite Diesel is one of our sponsors, just go to the sponsor page and there will be a link for them, make sure to mention that you are a member of the forum here, could be good for a better price.
Gord. |
![]() If you have hgih miles, it should help alot to get the injectors matches and cleaned up. It should also help with just rebuilding them. I just removed my 175Kmile injectors, and the nozzles were pretty dirty, even after running Diesel Kleen for the last 3 years. It had 145K on it when I got it, so who knows how it was maintained and if it idled alot. I hope my mileage picks up a little. We'll find out! |
You may want to consider the DIY injector kit out there as well.
Performance Injectors for 7.3L Ford Power Strokes HEUI-Injector-Teardown-and-Assembly The first link is the injector kits, and the second link is an article on tearing down and puting them back togeather. Hope it helps. Gord. |
Thanks! So it does sound like that surge is an injector issue? |
I am not a tech, so I don't want to say yes and possible lead you in the wrong direction, your best bet is to do a buzz test and check the contribution on the injectors to find out if they are the problem. This is just very similar to a problem I had on my truck, and it turned out to be a bad injector. You have not mentioned whether you have pulled any codes off it yet, might be a good idea, give you more to work with.
Gord. |
yeah, what he said...
hahahaha thats funny.
