DCP INJECTOR NOZZLES
I have just ordered 70hp nozzles from dcp has anyone had any prior experience with installing these are there any internal orings in the injectors that need to be replaced? I also ordered a hpop from diesel site to go along with these nozzles.
Are you stock split shot injectors still and adding these nozzles???
dcp????? id like to know more about this
truck is a 2000 model split shots website is dieselcare.net
do you think my stock fuel pump will still be able to keep up
In all my search and asking everyone lol Its alot more econimical to run bigger single shots than it is to just add nozzles for more power. Its alot harder to tune with big nozzles and stock injectors than it is to tune with big injectors and smaller nozzles.....
Are you running a chip already as well??? You more than likely wont see that full 75hp and it will be a bit smokier and higher egts..... Just my .02$ Not trying to ruin your mood or nothing but I would really recommend going the other route.... Let me rephrase actually if you are already chipped and looking for more power I would go bigger injectors with stock or slightly modified nozzles-- If you are stock tuning no chip and want more power than the nozzles will be ok, if you do have a chip tho with that extra capacity thru nozzle the stock injectors empty so fast already that with that much extra volume thru nozzle its really really hard to tune the truck actually really well because you have almost no difference between how much fuel is coming out of injectors at idle and full WOT.... with a big nozzle on stock injector it pushes all the fuel out literally right off idle.....Hope Im making sense with this lol Last edited by Grease Monkey; 12-09-2009 at 01:02 PM. |
The adrenaline Is a great buy tho, You will be very very happy with that, How much did you pay for the nozzles tho?
stock pump will be fine. Adrenaline will help alot and your stock injectors will work.
subscribed
Subscribed to see how the nozzles do. It sounds like a pretty fair price for 70-100 extra hp.
