Oil changes - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-09-2009, 08:20 AM Thread Starter
fred 156-M's Avatar
Oil changes
I've herd that there is about 3 Qt. of engine oil (in a '03 7.3l) that doesn't drain when the pan plug is pulled.
The story that I herd goes,
1. Change Engine oil as normal.
2. Remove a (pipe) plug at the front of the engine, just to the right of center.
3. insert a rigid tube, & remove about a Qt. of oil with a vacuum set-up.
4. Run the Engine for a couple of minutes.
5. Repeat step 3 & 4, recheck & top off Oil. (oil removed will be black)
5. Repeat step 3 & 4, recheck & top off Oil. (oil removed will still be black)
6. Repeat step 3 & 4, recheck & top off Oil. (oil removed will start to look cleaner)
The story that I herd continues that this is oil that has to do with the fuel pressure regulator, and such.
Any one ever here of this, TSB's or other wise?
thanks
Fred 156-M
fred 156-M is offline
post #2 of 4 Old 12-09-2009, 08:35 AM
Quoted: 176 Post(s)
Feedback Score: 3 reviews
I don't mean to be short with you....
This question has been asked 1,000 times (search HPOP oil change maybe) the answer is;
There's only 1 idiot on the planet who recommends this and, from a technical point this guy is absolutely clueless. He's got some interesting videos but many of his theories are just Wack!
So, no, you don't have to do ANYTHING like that. If that's not good enough, do the SEARCH
NoRalPh is offline
post #3 of 4 Old 12-09-2009, 08:47 AM Thread Starter
fred 156-M's Avatar
An honest answer is exactly, what I was after.
Much appreciation.
Fred 156-M
post #4 of 4 Old 12-09-2009, 09:03 AM
ryandamo's Avatar
ehhhh i still do it along with quite a few other people in my area at oil changes as well as other forums, keeps your oil from turning black right after you change it...... its more for the injectors than a lubrication viewpoint since the injectors use high pressure oil to fire them. cheap insurance if you ask me.
2016 F450 6.7L XLT 4x4Dump, bone stock
1994 F250 7.3L XLT 4x4 ZF5 , Centurion, 4" Lift, 6637, Gulf Coast Bypass Filter, Big fuel tanks, dana 60 swap, No longer dually
1997 F350 7.3L XLT 4x4Dump, E4OD, 4 in exhaust, TS 6 position, 3/8 Trans line+external filter
2013 Scag Turf Tiger 61" 1.1L Caterpillar Diesel
1960 John Deere 440 Backhoe 2-53 detroit
ryandamo is offline
