Can i put heated power mirrors onto my 99.5? - Ford Powerstroke Diesel Forum
Old 12-08-2009, 06:09 PM
I have power mirrors on my truck now. Is it possible to put on the heated power mirrors with turn signals? I have a chance to buy a set.
How hard is it to change?
Do i need a whole new wiring kit or will it be able to simply plug into what I already have on the truck already.
Old 12-08-2009, 06:19 PM
Yes in fact do a search, I found it on here and he had everything listed along with the turn signal wires and everything...
Old 12-08-2009, 06:40 PM
I must stink at what words to do for the search on this site.
I tried and couldn't find the info I was looking for.
Any chance of a link.
Old 12-09-2009, 04:35 AM
Yeah, the search feature on this site sucks! I would say you'd have no problem getting the turn signals to work, but you will have to run a wire to the mirror and find the turn signal wires under the steering wheel, which should be easy if you have the wiring info. About the heat- I'm not sure, but it shouldn't be too hard.
Old 12-09-2009, 04:47 AM
Try searching "mirror swap" I got a lot of results that way
heres a thread you may want '03 Mirror Swap - All Done! - Ford Truck Enthusiasts Forums
Old 12-09-2009, 04:49 AM
You're gonna need to do your own wiring, but it shouldn't be too bad. You'll need to tap into the running lights, turn signals, and some source of 12v+ when the key is on for the defrost.
Wiring here
08 power mirror swap wiring fix
Old 12-09-2009, 05:32 AM
Really helps if you know the proper wording for doing a search.
Thanks o0firemaster0o
