Level of performance vs engine life - Ford Powerstroke Diesel Forum
post #1 of 12 Old 12-08-2009, 05:15 PM Thread Starter
Phlord428's Avatar
I just bought a 2001 7.3 F250 that has a few mods installed.
I've never owned a diesel except my little New Holland tractor (no mods).
The truck came with an Edge tuner. I put around 500 miles on it and then decided to check what level of tune it was at since there's four choices including stock. It was at 2 or "race" according to Edge. I retuned it to level 1 for towing. I liked the way it drove a lot better at the higher state of tune but I'm wondering what that will do to the lifespan of the engine.
I actually bought the older truck just to get the 7.3 and its reputation for being bullet proof and don't want to be buying a diesel rebuild.
Phlord428 is offline
post #2 of 12 Old 12-08-2009, 05:45 PM
yup so dump the edge it doesnt program your tranny..therefore fried tranny. engine.. is a tank. come on its a 7.3! dont worry there.
Dietoremain is offline
post #3 of 12 Old 12-08-2009, 07:22 PM Thread Starter
Phlord428's Avatar
Manual tranny
post #4 of 12 Old 12-08-2009, 07:27 PM
ah nvm then. well there is honestly better custom programmed chips out there. but theres alotta people using edge too. from what i understand its all up to u!
post #5 of 12 Old 12-09-2009, 05:36 AM
Powerstroke Junkie
NCHornet's Avatar
Please fill out your sig so we know what has been done to the truck. Sure makes answering your questions a lot easier!!! I sure hope one of the mods you mention is gauges, because I wouldn't have bought a truck that ran any tunes without gauges. You should also have a better flowing intake and exhaust before running tunes. Have these been done? You don't need a full 4" system, the restriction in the factory set up is in the cheap muffler they used, they necked down the 3.5 exhaust to 2.5" to use a generic off set muffler that causes even more restriction!! Back pressure is good on a gasser, not on a diesel!!! Either straight pipe it or use the Walker BTM to fix the exhaust. You can see by my signature how I feel about generic tunes, so I would make sure you have the proper supporting mods and then save up some $$ for some decent tunes from TW, DP , PHP, etc....... the difference is night and day!!!
NCH
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #6 of 12 Old 12-09-2009, 05:57 AM Thread Starter
Phlord428's Avatar
My "new" 2001 F250 CrewCab Longbed 4x4
Manual 6 speed - stock diffys
Lifted ~4" w/ 315 75/R16 Tires
Mods I have found so far...
Cold Air Intake,Aftermarket Turbo Impeller (great whistle)
Defoiled, Edge Evolution, 5" Exhaust turbo to tail
GlowShift Pyro & Boost (tranny temp ) triple pillar pod
My "old" gasser 1974 F100 4x4 w/ BUILT 1968 428 Cobra Jet 500+ tq/425 hp
I know gas fords and am learning diesel.
post #7 of 12 Old 12-09-2009, 06:36 AM
superduty4x4's Avatar
I would get rid of the Edge if I were you. There are custom programmed chips that will be a lot better than what you can get from the Edge. DP Tuner, Total Diesel Performance, Power Hungry Performance, or Swamp's Diesel is where I would be looking. I'm running DP tunes in my truck and really happy with them so far.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #8 of 12 Old 12-09-2009, 07:22 AM
jesilvas's Avatar
Quoted: 2 Post(s)
Well seems like you're pretty set
Which kind of CAI do you have?
But other that that, pretty good. But a custom tuned chip will do a lot better, that's for sure.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #9 of 12 Old 12-09-2009, 11:54 AM
the1laf's Avatar
So how much hp and torque can I crank out before having to upgrade something besides the clutch?
She's running 264,000 miles, and started great today at -14*
What is a reasonable level?
What #'s will a good tuner do?
It's mainly a daily driver and towing machine, but I want to smoke my friends ricer when I get the chance.
2000 F-350 Lariat CCLB w. 335,000+ Mi
Tymar intake, Straight 4", 6.0 Intercooler, IDP Competition Fuel System, AC's, SB SD Clutch, ZF6 Short Shift Kit
Gearhead Tunes, Swamps IDM, Snow Performance Water/Meth, Isspro Performax Gauges & 08 Black Leather Seats
05 Harley's, Smoked tails, Weld Racing Sidewinder Wheels
Fried Piston, Re-building engine
330 RWHP Fuel Only - 363 RWHP w. Meth
Broke College kid... Eating Ramon to save for truck parts..
the1laf is offline
post #10 of 12 Old 12-09-2009, 12:26 PM
injection direction's Avatar
congrats on your new powersroke
I never got into the whole cobra jet thing but, I had several 460 trucks that I loved. When I finally made the switch to the powerstroke I was SOOOOOOO much happier with my setup than with the big block gas drinker.
I am a BIG advocate of keeping the powerstroke as close to stock as possible as far as tuning goes. The higher flowing intake and exhaust are in my opinion great mods to make from an efficiency stand point.
From what I have heard, if you want to go for a tuner the DP is a great way to go.
Injection Direction
1999 (early, 10/98) F250 XL CC/LB 4WD 4R100, str8 pipe, CCV mod, bypass trans filter, 3.73, DIY napa air filter, 261k
1995 E350 XLT str8 pipe, SS (super stocker), 321k
No replacement for displacement
injection direction is offline
