oil leak - Ford Powerstroke Diesel Forum
Old 12-07-2009, 10:48 AM
oil leak
i have a oil leak in the valley of my motor, and im starting to think its the hpop o-rings, because its right under the fuel filter bowl and drains down the tranny. i was wondering if anybody had a step by step post on how to fix this and what parts do i have to remove to get to this o ring.
Old 12-07-2009, 10:55 AM
scuffs *****
Send a message via AIM to Tyler
The HPOP is infront of your fuel bowl... giant piece of gray aluminum. You have to take the cover off your fuel bowl area, and that should be about it. Get a few open end wrenches (not sure what size) and go to town. Replace them anyway since your checking even if its not your issue, its like $2 for o-rings.
Old 12-07-2009, 11:39 AM
i checked that and i didnt see any oil coming out of the lines, from the pump, but i see alot of oil in the valley.
Old 12-07-2009, 11:41 AM
If it's the plug on back of the HPOP it's a 13mm I think. You take off the plug, new o ring, tighten it up.
Old 12-07-2009, 11:43 AM
ok, when i unplug these, will oil shoot out and whats the part number on these ?
Old 12-07-2009, 11:48 AM
Not a lot. You will only lose what is above that plug on the oil level. Which isn't much.
Old 12-07-2009, 01:41 PM
scuffs *****
As long as its not running
If its in the valley, you need to check your pedistal o-rings, make sure no oil coming out of the turbo.
Old 12-07-2009, 04:59 PM
what are places that i can tell if its coming out of the turbo?
Old 12-07-2009, 05:09 PM
Under it? Sorry idk.
Yes I do. I think. I know there's some write ups in the repair section. I think the most common is where the pedestal oil attaches to the valley.99-03 7.3 oil leak diagnosis
I probably told you wrong. Read that
