Pop after warm start up - Ford Powerstroke Diesel Forum
Old 12-04-2009, 01:25 PM
Hey all. first off, tried a search and didn't find anything...
Second...the truck... 52,000 mile 2002 F-350 CC DRW, AIS and MBRP only.
Third...the issue:
When the truck is already warm. So lets say I drive for a bit, stop at the store for about 10 minutes, hop back in, fire her up, 10 seconds later there is what sounds like a deep "pop" coming from the passanger side of the engine compartment. Almost at foot level of the cab. And only one.
I have only had the truck about 2 months, and its a regular occurence. No check engine lights.
I have no idea what it is...you?
Old 12-04-2009, 01:34 PM
Is your foot on the brake pedal when it happens? My abs module on both of my trucks will do that when it runs its self test. Its usually when im pressing the brake though, like if I start the truck and take off before it has a chance to run the test. Basically the abs self test becomes loud if theres brake pressure being applied.
Try pulling the big abs maxifuse, and if the noise goes away then put the fuse back in and dont worry about it.
Old 12-04-2009, 05:00 PM
No, my foot is not on the brake when it happens...Odd thing though today. It did it when I got off work today. Truck had been sitting for 10 hours. And it was 55 degrees out. So I guess its doing it cold too...
Old 12-04-2009, 05:26 PM
Send a message via Yahoo to carnival owner mikey
ive seen this on here but cant recall what it was........... pushrod?
Old 12-04-2009, 06:22 PM
I hope not...
Old 12-04-2009, 06:32 PM
i have a 1999 f350 with 276000 on it and does same thing. i noticed when it does it the oil pressure goes up. i maybe wrong but thats one thing i saw.
Old 12-05-2009, 08:17 AM
Hmmm. I am going to have to watch for that
Old 12-05-2009, 09:26 AM
Lifetime Premium Member
Mine makes a sound similar to what you are describing.I am leaning towards the caliper sticking on mine.
Old 12-05-2009, 10:14 AM
I am fairly certain its not the caliper sticking. It happens with my foot no where near the brake pedal as well as with my foot on the brake pedal.
I would be happy if it were just a sticky caliper...lube it and problem goes away...
Old 12-05-2009, 05:38 PM
Might try having someone take a ride with you and see if they can help you narrow down the area its coming from.
