NEW HEADLIGHTS??? - Ford Powerstroke Diesel Forum
Old 12-03-2009, 03:24 PM
Send a message via Yahoo to F250 Fever
NEW HEADLIGHTS???
So I jus bought some new headlights off ebay, I'm at work right now and jus wondering. If some of y'all could give me a few hints on making this easier on a kid with his psd thx guy preciate any info and I was lookin at one of the threads and someone. Said you have to take of the bumper to take out the headlights??? (I'm replacing the entire headlights not jus the bulbs)
Old 12-03-2009, 03:50 PM
Lifetime Premium Member
What headlights did you get?You do Not have to remove the bumper,that I am aware of.I just put 03 headlights in mine,No problems.
Old 12-03-2009, 04:03 PM
I also put 02-04 headlights in today, but mine is an XL. A little different because mine had the sealed beam lights. If your doing a swap from sealed beams let me know. There are a couple of things to look out for.
Old 12-03-2009, 04:32 PM
OK, I am going to slightly hijack... When upgrading headlights to the 02-04 headlights you do not have to do anything but swap, right? no trimming/harness changes?
When upgrading to 05-07 headlights exactly WHAT ALL is required to put them in these trucks?
Old 12-03-2009, 04:48 PM
To upgrade to the 02 to 04,I did nothing but plug them in.Not sure about the other years mentioned.
Sorry for the Highjack OP.
Old 12-03-2009, 04:51 PM
BOSS LEVEL
just finished mine today. the pass side of the bumper is higher so it was a pita to remove and put the screw back on.
Old 12-03-2009, 05:08 PM
Mine is a '99 XL. If your upgrading from the sealed beam its a little different, for me at least. There is a harness for the 6054 plug for the sealed beams that connects from the 9007 plug. You follow the wires about 6" back and the 9007 will be behind the header panel. Also 2 of the 3 the holes on each side that the lights pop into didn't hold for me. I had to use some hitch pins to hold them tight. That part was probably not common, but I guess can happen. The 9007 plug is something that took me a little bit to figure out because its not visible.
Old 12-03-2009, 05:45 PM
Ok thx for all the help guys I bought the halo projectors and they are not the sealed beam type.
Old 12-03-2009, 05:51 PM
So I'm sure I jus unscrew some things and swap old for new and plugem in? And align them so I'm not gettin the bird from everyone..lol
Old 12-03-2009, 05:54 PM
Smile New Headlights???
Hi,
What brand of HID lights are best buy? I like to see at nite and would like an idea of the cost and manufacturer of the kit.
Thanks,
Mike
