15 inch rims on 1996 f 250? - Ford Powerstroke Diesel Forum
Old 12-03-2009, 07:52 AM
Hi folks,
Do you know if it is possible to run 15 inch wheels on a '96 f250? Seems like R15 tires are cheaper than r16's.
Right now, I run 285's. If I added wheel spacers and cut enough of the front bumper out to avoid rub there, how big of tires could I squeeze and avoid the leaf spring rub?
The truck is not lifted.
Thanks!!
Old 12-03-2009, 07:57 AM
its possible if you have a rim will a hole lotta off set but most factory 15 wont work hope this helps
