What rear end do I have? - Ford Powerstroke Diesel Forum
Old 03-21-2007, 04:21 PM
Send a message via Yahoo to '90 SSC Clone
Hello guys, I'm new to the big trucks and trying to learn a few things. I have a '02 F-250 CC with the 7.3L in the Lariat package. I do have 3.73 rear end gears but it is an open unit.
I would like to put a posi unit in it but not quite sure what rear end it is. Is it a Dana 60?
And would any of you know of a good place to get a posi unit? E-bay maybe?
Thanks,
Bobby
Old 03-21-2007, 04:23 PM
I would at least price an electric locker
Old 03-21-2007, 04:32 PM
Jon
Guest
Posts: n/a
beepbeepbeepbeep, I should know this
I think its the Ford 10.5.
Old 03-21-2007, 04:40 PM
Send a message via ICQ to Lord Tauk Send a message via AIM to Lord Tauk
I thought it was either Sterlings (Ford) 10.25'' or 10.5'', diff housing and cover being the same.
I always assumed every Superduty had a factory limited slip, mine does and I just have an XLT - Are they ordered with or without? Put on the dealer lots with and without?
Old 03-21-2007, 06:06 PM
International Threat
Up front you have a Dana 60, out back you have a Sterling 10.5".
Check your Diff tag on the right hand side of the diff cover, and tell us what it says. That will tell us if it's open, or L/S. You might have a L/S that needs rebuilt b/c they have been known to wear out quickly.
Hope this helps.
Old 03-21-2007, 06:34 PM
Okay, here is what the tag has on it. Granted, it is still bolted to the rear end, therefore can't see a couple of the numbers.
Top Row: 3 S 409 H
Bottom Row: L73 10 5 1L26
I am assuming this is a 3.73 gear ratio. But does the L indicate a Limited Slip?
Every great once in a while it will spin both tires, but for the most part it only spins the right. At the track it only spun the right.
Thanks,
Bobby
