oil pressure gauge question
The stock dash oil pressure gauge, is this one of those that only has a couple places to read? Like too low, ok, high?
Where can i hook a real gauge to to check actual pressure? What should it be reading? whats good oil pressure on a 7.3 at idle? My factory gauge takes a couple maybe a few seconds to get a reading after the truck starts? Is this normal? I am sure it takes a brief period for the oil to get to the sending unit? |
anyone know....
Are you wanting to check LPO or HPO?
Mine takes about the same amount of time to jump up too. |
Yes it takes a couple seconds... it is reading the pressure in the top of the reservoir. Not sure what numbers are good though...
lpo
thanks |
Oh not a clue on pressures for LPO
which sending unit is it? The tip top of the reservoir?
Yep, the one on the side of the reservoir is EOT (Engine oil temp)
