Wont go into park need HELP.......
I have a
Is there a write up on dropping the colum on this truck ( I searched but didnt find one ) I did read somewhere that there are some brass torque screws in there that might work loose and allow this to happen. Any thoughts and advice will be helpful. Thanks Cliff |
At the bottom of the column there are 2 torx bolts where the shift linkage hooks. I have seen those bolts come loose on many trucks with your same problem. Easy fix, just lay on the floor and tighten them up, no need to pull the column.
Thanks Chad i'll try that.
Well I looked under the colum and there were 2 loose torq screws. I tightened them up and it fixed it. This forum has saved me some more money
Thanks Chad 5.0 and Thanks Powerstroke.org for this forum |
