would like to convert front axle to dana60 from the 50 - Ford Powerstroke Diesel Forum
Old 03-21-2007, 06:20 AM
Send a message via AIM to gliddec176
does any one know what year super duty had a 60 in the front? i want a stonger front end but i dont know what years i should be looking at in the junk yard
Old 03-21-2007, 06:23 AM
Almostdunfukinwidit
I think it was 6/00 and later but am not sure
Old 03-21-2007, 06:25 AM
HardLuck Case of the Year
Send a message via AIM to Ditty Send a message via Yahoo to Ditty
My 2000 F350 has a Dana 60 up front. I THINK all the 350's from at least 99-03 had the 60 up front, though I've been wrong before.
Old 03-21-2007, 09:01 AM
International Threat
I'm pretty sure the D60 only came in DRW setups from 99-01 and the D50 came in all SRW trucks in the same years.
Beyond 01 D60 was standard in both SRW and DRW.
Problem is, the D50 looks the same as a D60 and the guts are different. Only issue I think in switching would be if you had an early 99 without ABS.
Should be a direct boltup.
But like Ditty said... I could be wrong too lol...
Old 03-21-2007, 09:43 AM
duct tape & zip ties
Depends on how old of a D60 you want. The old military pickups and Cucv's ran D60's up front. You can get ahold of one of those axles pretty cheap. If you do get a D60 before you install it I would be adding a true trac kit from detriot locker. That way you have added traction in 4wheel drive. Or if you have the money better yet an electic locker from Detriot would be even better.
Old 03-21-2007, 12:36 PM
The pinion is longer on the 60. You can source a shaft in the right length or have it cut.
