7.3 swap into v10 frame?
is it possible, buddy of mine crashed his truck, messes his cab up but his frame is still good. i found a 4x4 v10 truck with a bad motor, and we are thinking of using that cab and box and throwing it on my buddys frame. is it possibly to put my 7.3 in a v10 frame. then i would just swap my cab and box onto that frame and have 4wd. not sure but i think i would need a 4x4 tranny out of a diesel but not sure
I doubt it, the 7.3 weighs a lot more than the V10, but do some measurements, maybe Ford didn't produce a lighter frame for the V10 version because not as many were made? I am sure the springs are different.
NCH |
not worried about the springs, i want to put in 1ton springs front and rear. im just wondering if the front axles are the same, and if the engine mounts can be swapped
im sure they are the same..why would they make a diff frame..axles should be too just see if there 10.5's there should be a tag on the diffs..
whats the years of these trucks i can check..
mines a early 99, v10 truck is 2000
