white smoke. please help!! - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-20-2007, 05:28 PM Thread Starter
hey guys. I know that white smoke on first start up on cold mornings is pretty normal or so i've been told but it is about 45 degrees out and I get white smoke for about 5-10 minutes on first start up and the truck seems to not want to go anywhere until warm. Once the truck has warmed up the smoke stops and the engine runs great. Any ideas?
1999 f250 superduty PSD.
tymer intake
4" MBRP exhuaust
superchip programmer
3" lift
dfuser 18K module
quadzilla commander
dieselbop is offline
post #2 of 7 Old 03-20-2007, 06:15 PM
You may have trash in your fuel, or may have an injector issue. ULSD has been causing injector issues with the 7.3's. Check your fuel filter, if its black in color that means you have picked up some trash in your tank most likely
Shaump is offline
post #3 of 7 Old 03-20-2007, 06:48 PM Thread Starter
any other ideas?
tymer intake
4" MBRP exhuaust
3" lift
dfuser 18K module
quadzilla commander
post #4 of 7 Old 03-20-2007, 07:07 PM
F-350MAN's Avatar
what kind of problems???
2001 F-350 CC LONG BED
SuperChips Micro Tuner
10k mod
4"turbo back silverline W/muffler delete
DIY tymar
ZooDad
ccv mod
Foil Delete
6'' Fabtech 2wd lift,on 325/70/18's open country
FORD MAKES IT
INTERNATIONAL
SHAKES IT !!
F-350MAN is offline
post #5 of 7 Old 03-20-2007, 07:46 PM
purduefarmboy460's Avatar
Send a message via AIM to purduefarmboy460
Glow plug relay could be bad, I thought my truck was literally falling apart, replaced the glow plug relay, all is well again
purduefarmboy460 is offline
post #6 of 7 Old 03-21-2007, 04:45 PM
keystone crawler's Avatar
just about to say that if can rule out bad fuel . relay are cheap time to time there are some on ebay
99 PSD F250 DD / toy hauler
94 YJ 2.5 slow and not street legal anymore
keystone crawler is offline
post #7 of 7 Old 03-22-2007, 02:35 PM
I've had fueling issues that I brought upon myself (bad fuel...long story) but I've found that fuel starvation conditions make for white smoke.
My mechanic confirmed this.
ProGunProgressive is offline
