Thank you...THANK YOU!!!
693 views 4 replies 4 participants last post by  purduefarmboy460
#1 ·
:thumb: I just wanted to thank you guy's for helping me out with my problem. I did what you suggested and you were right on the money. The shift lever wires had been shorting out and causing all the headaches. I can't believe that Ford didn't have a recall on this. It is and will be a problem if not properly corrected. I see what you also meant by rerouting the wires. It is a must or the problem would return in due time. Thanks again
