Boost - Ford Powerstroke Diesel Forum
post #1 of 16 Old 11-27-2009, 11:10 AM Thread Starter
SpeedyDBall's Avatar
Boost
Im sure there is a post on here already about upping your boost level on the stok turbo I just havent found it yet. Is this possible? How? Not wanting to up it alot. Mabey take it up to 28-30 lbs. Is this too much?
SpeedyDBall is offline
post #2 of 16 Old 11-27-2009, 11:13 AM
Raul@Stealth Automotive's Avatar
what kind of mods are you running? the stock turbo can achieve 30psi but your going to need a chip or tuner and even then its already into the area where its prob doing more harm than good..... what kind of boost numbers are you seeing now?
-Raul
Raul@Stealth Automotive is offline
post #3 of 16 Old 11-27-2009, 11:23 AM Thread Starter
I have a afe stage 2 intake, 4" turbo back exhaust, and an dge evolution. I just notice on the 100 hp tune I smoke ALOT. I was thinking if I could pick up boost a little bit I could make a little more power with all that wasted fuel. i dont want to hurt my truck though.
post #4 of 16 Old 11-27-2009, 11:25 AM
what boost numbers are you seeing?
post #5 of 16 Old 11-27-2009, 12:15 PM
<< Representin with INK
Grease Monkey's Avatar
With the ported compressor housing or Wicked wheel and also a 1.00 A/R turbine housing you should be ok pushing 25-28 lbs if you also have an adjustable wastegate or turbomaster wastegate controller. However if you do tighten the wastegate up and you are not surging but you as well do not see more than say 25 psi I believe that is all the air that the turbo will push. If you try and make it boost more its really just making the air hotter and you wont make any more power. But like mentioned earlier what boost are you running now and it will be easier to tell you what you can do to get a little more.
00 3/4T Ext/Cab SB 4wd
Any and All diesels in Southwest welcome to join!
GREASE MONKEY KUSTOMS Rod & Speed Shop Open 2010
Grease Monkey is offline
post #6 of 16 Old 11-27-2009, 12:17 PM
no-tel-in's Avatar
custom tunes! ditch the edge
2000 F-250 4x4 7.3
BTS Transmission - 6.0L Cooler
GTP38r
Full Fuel System with Return
2-Stage W/M & Nitrous
Adrenaline HPOP
238/100's
no-tel-in is offline
post #7 of 16 Old 11-27-2009, 12:19 PM
this is how i think about it.. by the time you end up buying all that stuff you are more than 3/4 away from a 38R. might as well spend a lil more and get a better turbo
-Raul
post #8 of 16 Old 11-27-2009, 12:34 PM
Send a message via MSN to Iceman_19
What kind of boost can the 38R push?
2002 F-350 (sold)
CC SB
K&N intake w/ 6637 Filter
4" turbo back straight pipe
Superjunk tuner
Dieselsite.com Boost Fooler
Unhooked wastegate
05 front end conversion
6" lift
37" bfg muds on 20s (summer)
33" all terrains on 16s (winter)
6 spd manual
Iceman_19 is offline
post #9 of 16 Old 11-27-2009, 12:38 PM
no-tel-in's Avatar
about 40 lbs.
2000 F-250 4x4 7.3
GTP38r
Adrenaline HPOP
238/100's
post #10 of 16 Old 11-27-2009, 12:39 PM
More then my rods can handle, perfect!
2002 F-350 (sold)
CC SB
Superjunk tuner
Unhooked wastegate
6" lift
6 spd manual
