I was looking for either a new oil drain plug/washer and considering the fumoto since mine started leaking today. Randomly came across this kit online and it reminded me of folks in the rust belt.
Same with me, if I were going to spend that much for a band-aid, I would go
ahead and replace it with a new one. If he is making these out of fiberglass,
and then gluing them onto the pan, why couldn't you just clean your oil pan
and do a fiberglass right on the pain. You would have to talk to others, because
I don't know how well fiberglass holds up to heat. Good luck,
now go put on a new pan. LOL:frown2:
Doug
It's an interesting idea, the compounds it uses aren't cheap, here's a good vid on the process ->
Edit: Shoulda scrolled down on that page, didn't notice the vid was there already...
This has actually been around for some time. I think it has a pretty good success rate and, if you look what doing a pan change the "right way" costs, you'd find the $300 an awful cheap alternative!
For $300 you could get an engine hoist and stand and do it yourself. Then you would have them to use later.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
