99 auto trans fluid ? - Ford Powerstroke Diesel Forum
Old 11-24-2009, 02:58 PM
i have an early 99 with an auto trans. at fluid change does it take dex III or merc v?
Old 11-25-2009, 05:19 AM
Powerstroke Junkie
NOT AGAIN!!!!! Please use the search engine, look in your owners manual etc..... But to answer your question it only should have Mercon/Dexron III not Mercon V even though Ford is trying to convince people it is okay. If you need the flush procedure use the search engine, I have posted it many times. Oh, you won't find Dexron/Mercon III since it hasn't been manufactured under that name since June of 2007. But Napa has a fluid simply called ATF that is the old Mercon/Dexron III and it is good oil made by Valvoline. PM me with any ?
NCH
