I can't figure out if I need to look into this I can't tell if it's a knock or if it's my down pipe it's a 4inch down pipe.its really been stressing me out. Thanks for any help two videos on my YouTube channel
My God, what did you do to that once princess in photo besides letting surface rust start jumping on it?
No! No bad internal death knock!
Very"lopy" it's out of "balance". This can be via fuel delivery or electronic command delivery failure.
Could write page long detail, not going to. I'm going to show a short cut to a path, to start down...
Like you brought that camera into the wheel well... we'll get a little further under. Once under with goggles on to keep things out of your eyeballs, point a temp reading gun up to each cylinder's exhaust port going into manifold. Identify non firing/weak producing cylinders and use as a base for further diagnosis. Cylinders all pretty close in temp but acting like that? Chase base fuel supply...i.e. Lift pressure/ flow (not one in same), AERATION(the biggy for loping) and can be found by trying to run up to 3k rpm held steady with pedal but tach wants to "hunt".
I'll be here all week ��
I don't know it's just a different tone. If it's sitting next to another 7.3 it puts off a different sound coming from the passenger side if you go over to the driver side you can't hardly hear it. Also can't hear it from the front end or from the top of the motor.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
