squeal from underhood - Ford Powerstroke Diesel Forum
post #1 of 16 Old 11-23-2009, 04:41 PM Thread Starter
O.I.F. Combat Vet 11B
Well, I replaced my tensioner last week and noise went away for a few days. Got home from out of town this weekend and fire the truck up to a nice loud new noise from under the hood. I am kinda thinking it is the idler pulley but not 100% yet. The noise is loud while going through the gears but goes away once you put it in nuetral. I no it is either belt or a pulley somewhere due to going away once I spray some wd40 on her. Just wierd that it gets louder with acceleration and does not make the noise at idle.
ju015dd is offline
post #2 of 16 Old 11-23-2009, 05:22 PM
I had the same problem recently and found out that some of the belts out there were actually not the right width. I replaced mine with a new gates and it went away instantly. I had changed all the idler pulley bearings first since that is what it sounded like. Good luck.
2002 F-250 4x4 cc A/T
4" Magna Flow Exhaust
PHP Chip-Stock, 40, 60, 80, 100, Whisper
BF Goodrich 33s
ZooDad
Autometer Trans,
Pyro,Boost on the pillar
zeuss is offline
post #3 of 16 Old 11-23-2009, 05:28 PM Thread Starter
you can just change out the bearing in the idler pulley? No clue how old the belt it on my truck but it isn't cracked or missing any ribs. Prob still gonna change it out though.
ju015dd is offline
post #4 of 16 Old 11-23-2009, 05:48 PM
joeniel's Avatar
Send a message via AIM to joeniel
Is it normal for belts to squeal when I start it up in the morning and go away once its warmed up?
2002 F350 7.3
PHP FU, Isspro's, DIY Intake, 5" Stacks, WW, 08 Mirrors/Gate/Tails.. etc
Pics and full list of mods
Waltham, MA
Looking for an 8 foot bed in the New England area!
If you have one, or know who does, please PM me.
joeniel is offline
post #5 of 16 Old 11-23-2009, 06:02 PM
You can change just the bearing. I bought mine at the electric motor shop. They just pop out and in. Use a socket the same size. As far as a squel when cold, I would think it is a indication of bad belt or improper tension. Or possibly a dry bearing. Just have to look at it.
BF Goodrich 33s
ZooDad
Autometer Trans,
zeuss is offline
post #6 of 16 Old 11-23-2009, 06:25 PM
7004's Avatar
you can buy the pulley for $26 at autozone. just picked 1 up for me today
Early '99 F-350 Ext. Cab LB
TS 6pos. Chip
Tranne is all better
K&N Intake
Zoodad mod
4" Downpipe
MBRP 5" Exhaust w/6" SS Tip
Boost Fooler
Quadzilla Recon
(Sold)'96 F-250 Ext. Cab LB
CENTER][URL
7004 is offline
post #7 of 16 Old 11-24-2009, 03:16 AM Thread Starter
sweet, thanks guys!
ju015dd is offline
post #8 of 16 Old 11-24-2009, 03:34 AM
Powerstroke Junkie
NCHornet's Avatar
The easiest way to find the source of the noise is to take a wooden dowel, or wood handle and place it around different places of the engine. You can actually feel the noise through the wood. Old, Old mechanics trick.
NCH
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #9 of 16 Old 11-25-2009, 05:54 AM Thread Starter
anyone know where to get alternator pulley? thought it was the idler but changed that out and still have the noise. I can push on the pulley and sounds like the alternator making some squeaking.
ju015dd is offline
post #10 of 16 Old 11-25-2009, 06:17 AM
KeepinItFord's Avatar
Check your belt, it migth be cracked and hardened
KeepinItFord is offline
