Typical RPM at idle? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-15-2017, 01:40 PM Thread Starter
Quoted: 3 Post(s)
Garage
Just got another 7.3 for my dad and it came with an edge programmer on it. It's a 2001 with 153k miles! Before handing it over to him I wanted to make sure everything is straight. The edge programmer that's on it is one of the 1st generation ones, that's gives me a simple small screen that displays the RPM, Boost, EGT, and battery voltage. The RPM, without looking at the gauge feels to be pretty low at idle, its not necessarily so low that it feels like it's going to die, but the reading for RPM gets as low as 654 and I just feel like that's pretty low. It vibrates a little more than my personal 7.3. Any suggestions on if that RPM at idle is normal or not?
Cvaughan73 is offline
post #2 of 10 Old 03-16-2017, 12:47 PM
greenskeeper's Avatar
Quoted: 84 Post(s)
sounds normal
Gunga galunga...gunga -- gunga galunga.
97 F-250 CC 4x4 7.3L PSD E4OD
99 F-250 CC 4x4 7.3L PSD ZF6 E99 CALI DELETE
ROTELLA 5W-40, MOBIL1 ATF, PENNZOIL SYNCHROMESH
greenskeeper is offline
post #3 of 10 Old 03-20-2017, 08:56 AM
FullyTorqued's Avatar
Garage
Yeah that sounds about right, my 99 will idle about there. Unless its cold, then it will start at about there and jump up to 900 or so after a few minutes.
FullyTorqued is offline
post #4 of 10 Old 03-20-2017, 09:53 AM
97powerstroker's Avatar
Quoted: 8 Post(s)
Normal idle in my opinion.
2002 F-250 7.3 auto CC/SB lariet 115k miles and 100% stock!
1996 F250 460-auto-ext.cab-long box-4.10-152k-10mpg all day running or not.....
97powerstroker is online now
post #5 of 10 Old 03-20-2017, 10:58 AM
WB5OXQ's Avatar
The 98 E350 that I drive once a week has a 7.3 and the device you described also and it idles at 735 rpm and vibrates a lot at idle. 180000 miles on this one. It also has very little power in first gear like there is no boost but when it switches to second and on up the boost comes on good. This is the biggest passenger model and I have no idea how heavy this truck is.
WB5OXQ is offline
post #6 of 10 Old 03-20-2017, 03:04 PM
Can't say exactly right now but I think my '02 7.3L idles about 800 rpm, will check next time I drive it and report back.
tvman44 is offline
post #7 of 10 Old 03-20-2017, 09:03 PM
6-J
Howdy, I have an Edge Juice with Attitude product on my 6.0 and send it in to the manufacture every couple of years for an update reflash. It takes a couple of weeks and it returns with a new feature or noticeable change. I once sent in the unit with the old thermo-couple and they returned it with a new one. What I am saying, the manufacturer has provided great customer service with me. I would suggest calling them and finding out if there are any updates for your Edge product.
To answer your question, my experience with idling issues is variable with fuel quality, outside air temperature, motor temperature, and DIRTY OIL.
That is my 2 cents.
KenO
Kenster in NW Wyoming
2003 F-250 6.0, 6 speed, one of the good ones
Enhancements:
Edge Juice, 4 inch exhaust, EGR delete, AirAid
Project: 1981 VW Rabbit pickup, 1.6 diesel
Because it is hard to beat 45 mpg
6-J is offline
post #8 of 10 Old 03-21-2017, 05:48 AM
Checked my truck this morning and it idles about 800 rpm according to the factory tach.
tvman44 is offline
post #9 of 10 Old 03-21-2017, 07:13 AM
Quoted: 4 Post(s)
I have a stock 2001 f350 6 speed, in warm weather or warm engine, it idles at 650 rpm according to the readout on my rpm controller. When the engine is cold, it will automatically idle up to 900-1400. Idled up rpm seems to depend on temperature, the colder it is, the faster it turns.
TempestV is offline
post #10 of 10 Old 03-22-2017, 10:17 AM
Justin@DP-Tuner's Avatar
Quoted: 54 Post(s)
Normal idle on a stock truck, when it is up to temp, should be around 680 RPM. Give or take a little bit.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
