COOLANT TEMP?? - Ford Powerstroke Diesel Forum
Old 11-21-2009, 07:00 PM
COOLANT TEMP??
Wat is the normal operating coolant temp for the 7.3, my truck runs 250+ on scanner at 70-75mph, installed new radiator and still 250+, is that high???
Old 11-22-2009, 06:36 AM
Powerstroke Junkie
I have never checked mine, the next time I go on a decent run I will hook up my AE and let you know, but 250 seems a bit high. Over heating isn't usually a problem as our cooling systems are pretty robust. What are you using to give you the reading? Are you sure it is accurate? Where are you getting the temp from?
NCH
Old 11-22-2009, 06:57 AM
im not 100% sure its accurate, it runs 180 all day long at idle only rises at hwy speeds, sct tuner is what im using to monitor it
Old 11-22-2009, 07:14 AM
Mine runs between 190 and 230 but never really any higher then that.
Old 11-22-2009, 07:47 AM
Feedback Score: 3 reviews
how do you check it with a sct ?
Old 11-22-2009, 01:04 PM
I do not know. I run an after market temp gauge.
Old 11-27-2009, 08:36 PM
well i have a X3 not X2, but u run the data logging it monitors boost, trans temp on 6.0's, ECT, IAT, etc...
Old 11-27-2009, 08:39 PM
250 is high. I knows it a 6.0 but right now with the cooler temps I rarely see over 170. During the summer I would see about 190-210
Old 11-27-2009, 08:42 PM
aluminum tubing engineer
...that sounds like tranny instead of engine. wouldnt your thermostat never open up runnin 170
Old 11-27-2009, 08:59 PM
No, its definitely not my trans. My trans runs hotter
If I play around a good bit I can get it up and over 180ish but just normal driving it will rarely get over 175
