4x4 Dash Light always on when truck is in 4x2 - Ford Powerstroke Diesel Forum
post #1 of 13 Old 11-20-2009, 09:57 AM Thread Starter
jamdallen's Avatar
If someone else has had this problem and fixed it, what was it? I'm looking for a place to start.
The "4x4" dummy light on my dash is always on. Sometimes the "low range" is on, but it is usually dimmer (I can see it's barely on at night). The light does not flicker or anything when I put the truck in four wheel drive. The 4X4 system is working fine. The four wheel drive works fine when I engage it, and also disengages when I shift it out. The low range works fine too.
The truck is:
2000 F-350 Crew/LB
120k miles
Auto trans
Manual transfer case with a 4x4 shifter lever on the floor
Manual locking hubs
Thanks!
jamdallen
jamdallen is offline
post #2 of 13 Old 11-21-2009, 09:27 AM Thread Starter
jamdallen's Avatar
Hmmm...No replies...Do I have a funky non-typical problem?
Jamdallen
post #3 of 13 Old 11-21-2009, 09:29 AM
GoldieStroker944's Avatar
my 01 did that when i got it...it would always stay on no matter what i did with the switch...i got underneth the truck where the vacuum line connects on the transfer case and it was almost completly unplugged i plugged it back in and never had another problem might start with all the vac lines its a start anyway
2003 7.3L
Crew Cab Short box
Lariat
Cowl (functional)hood
315/75-16 wild coutry A/T's
Hypertech power programmer 3
T.S 6pos
stock,high idle,50,75,100,140
AFE stage 1
Foil delete
MBRP Cool Duals 6" tips
Sirius sat radio
GoldieStroker944 is offline
post #4 of 13 Old 11-21-2009, 10:08 AM
I'm pretty sure he doesn't have the vacuum lines on his, its the shift on the floor system. Check all your electrical connections on your transfercase, its probably a corroded terminal.
2002 F350 SRW Crew Cab Shorty Lariat
Torredor Red - 7.3, Viper 5701
Silverline 4" TB Exhaust
Power Hungry Performance FU Chip
Autometer GS Gauges
md18 is offline
post #5 of 13 Old 11-21-2009, 10:36 AM
well none the less check ALL connections electrical and vaccum cause i still think it has something to do with engaging it?? but not sure
2003 7.3L
Crew Cab Short box
Lariat
T.S 6pos
AFE stage 1
Foil delete
Sirius sat radio
post #6 of 13 Old 11-21-2009, 10:38 AM
SuperCrutyPS's Avatar
Quoted: 312 Post(s)
Garage
Never mind - I just read that it's a 4x2.
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #7 of 13 Old 11-21-2009, 11:56 AM Thread Starter
jamdallen's Avatar
The truck is a 4X4. What I meant in the thread title is that the 4X4 light is on even though the truck is shifted into two wheel drive.
I can't see any wires/connectors going to the transfer case. Anybody got a clue where the wires are located? I don't think there are vacuum lines since it is a manual shift.
post #8 of 13 Old 11-21-2009, 12:00 PM
duct tape & zip ties
bigcountrysg's Avatar
Check the shift module on. It is located under the dash behind the glove box on the passenger side. At least on my 2002 that is where it is located. It is held in place by two 10 mm nuts and 7mm bolt. It has 3 wire harnesses going to it. Should have a sticker on it that states super duty 4x4.
Oh and there is no vaccuum lines going to the t-case. It has one vent on the top and that is it. But there is no vaccuum lines at all on the T-case.
The only vaccuum lines that are part of the 4wheeldrive system is the ones at the hubs on the front axle.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #9 of 13 Old 11-21-2009, 12:06 PM Thread Starter
jamdallen's Avatar
Do I have a shift module? It is a manual shift on the floor.
Jamdallen
post #10 of 13 Old 11-21-2009, 12:07 PM Thread Starter
jamdallen's Avatar
Jamdallen
I'll check anyway...
