My limited slip rear has become a one wheel peeler.. will changing fluid fix that?
I have a 373 limited slip rear, but 95% of the time only one wheel will spin (seems like the pass side) and it's driving me nuts! 500+lbs of torque plus a 6spd and only 1 wheel turning bites ballsack.
Somebody on here recommended changing the rear gear fluid and adding less friction modifier than is suposed to be in there. Will this work? I am pretty certain the truck has the stock fluid back there right now. But if this will help I'll be much more motivated to change it out lol. Matt |
It's worth a try because it might help and it is alot cheaper than pulling your differential out!
The friction modifier lets the clutches slip so you get a nice smooth ride when turning but then your limited slip won't grab and you end up with one wheel spinning. If you clutches are too far gone then it won't help. Mine was doing the same thing so I changed my fluid and added no friction modifier to it, but it didn't help, mine still spins one wheel ![]() My next plans are to put in a Detroit locker and not ever have to worry about it again |
How many miles till the clutches wear out? Thats kinda poohey.. i only have 143k miles
I dont care about a foofoo ride. It's a SUPER DUTY dammit.. key word SUPER- DUTY
Mine only has 60k mi. and has not been working for a long time!
damn seriously?? Thats nuts. What is involved in putting in a detroit locker? A whole new rear end or just internals or what? I'm not good when it comes to rear end parts and whatnot.
The Ford LS gets a bad rap because they don't work as they should because Ford calls for way to much additive to be used. This is no secret, it has been known for a long time. I replied to your questions in the other thread and don't feel like retyping everything, but to sum it up, changing the fluid correctly will make a huge difference and allow the LS to work as designed.
NCH |
Well I'm just making sure I'm not going to drop the money and time to do this and just end up pissed off because it didnt work lol
Whenever I took my vehicle in to those oil and lube stations, I think they used same fluid on every vehicle. No one ever said anything about friction additive what not. It appears this is one area where an owner has to get his hands dirty and do it himself.
Yes, in fact these people should not be allowed within 50 feet of any vehicle, lol
the gear oil is about 3 bux a qt. the XL-3 friction modifier is less than five. it would take less than an hour to change it out. only install HALF of the XL-3. go drive, problem solved for less than 25 bucks. if that don't work, GM makes a posi rejuvenator fluid, dont remember the part #, but parts dude will know. put that in there, works every time unless the clutches or springs is tader'd, now get after it, lol |
