can injectors make a loose lifter sound? - Ford Powerstroke Diesel Forum
Old 11-19-2009, 01:39 PM
I notice my tail pipe bent almost in half tonite. So I cut that part off. Then I said the muffler is outta here. I have a 4 inch ss straight thru performance muffler. I put that on in its place cause I had the adapter to make it fit. At this point i have no tail pipe on the truck.
I noticed a ticking lifter sound out the exhaust once started. Its the same sound in repitition with the sound from the front of the truck. My wifes has the same ticking type sound but not out the back, but she has a cat andd a stockmuffler. I am sure that would muffle anything. I know what the diesel noise is but this is like a loose lifter. But my other one does it too. I have a long lead ae injector in number 8 on my truck. It runs well.
Can the injector make this sort of lifter noise?
How would it come thru the exhaust like this? Do your guys do it too?
Old 11-19-2009, 02:03 PM
Lifetime Premium Member
Mine makes a ticking/knocking sound aswell.At times it sounds like the rocker arms are about to fly outta there.Then other times,it sounds like it is coming from the bottom end.Who knowsIf if blows up,then we will proceed to step 2
Old 11-19-2009, 02:18 PM
My wifes did it a lot when we got it(its gotten better and smoother). I put a hx line on hers and been running lots of diesel kleen power service thru it. Every tank for about the least 5k and now and its much better. I will do the hx line for mine too if I dont take it from her.
I was just wondering if injectors could tick like a lifter? The hx line from riffraffdiesel was well worth the 55 bucks(wpners for hers). I am willing to bet no one ever ran any ps thru my motor. I hope it will clear up as hers did when i start acyually driving it next week(just bought mine).
Can the idm do any ticking? ARe they silent
my truck hasthe long lead number 8 injector.
What seems weird to me that I hear it out the tailpipe too on mine. Same sound from up front, its in sinc. Like I said, she has the kitty and stock muffler on hersso it must drown out the noise.(big time not flowing)
last, can a turbo make a ticking sound? Or just a whine type bearing scraping sound right?
Old 11-19-2009, 04:32 PM
bump ............
Old 11-19-2009, 04:36 PM
another bump, i have the same noise, and was wondering also
Old 11-19-2009, 05:24 PM
yeah, i just kind of need to know if an injector can make a lifter type tick tick sound?
Injectors may not make any noice, i am not sure?
Old 11-19-2009, 05:28 PM
I have the regulated return on order.Hopefully getting the air out of the system might calm it down a little.I will let you know.
I bought the cross-over line(not the stainless)..I couldnt get it tight enough for my liking..still setting on the shelf.
