2000 7.3 oil requriments - Ford Powerstroke Diesel Forum
Old 11-19-2009, 07:17 AM
In two weeks, I'm goin to put a south bend clutch in my truck, and real seal in my differentail. I need to know how much and what kind is sugested for the trany, trans fer case, and rear differentail. I will be ordering the oil from AM's oil synthetic......
thanks
Old 11-19-2009, 09:07 AM
Powerstroke Junkie
The trans takes Mercon/DexronIII only and it stop being labeled that in June of 2007. Napa sells their own brand made by Valvoline that meets the same standards as Mercon/DexronIII it is simply called ATF, you will need about 20quarts to do a full flush, but capacity is 17 quarts IIRC. Don't let anyone tell you Mercon V is okay to use, even though Ford wants you to believe it.
Your rear axle in the dually is a Dana 80 and takes synthetic 75w90, IIRC 4 quarts will do it
The front axle takes the same fluid. You should have a LS in the Dana 80 and therefore you need to add the anti friction additive, don't add 80z that Ford says, this is why their LS has a bad reputation. Add 3oz and do some tight figure 8's, if you have chatter, add 1 0z at a time until the chatter goes away and your LS will work as designed.
NCH
Old 11-19-2009, 09:13 AM
Isn't Mercon V an improved Mercon? All I found at Autozone was Mercon V and it says exceeding all Mercon specs !!
Old 11-19-2009, 12:48 PM
I apprecaite the advice!
Two more questions I forgot to add. I'm goin to smoke my lights. How do you take the lights off an 08 mirror, and how do you take the dually fender lights out too?
I really apprecaite the advice.
