oil in intake tract and intercooler tubes
while pulling my valve covers today, i noticed there is a few teaspoons of oil in the intercooler tubes, and some on the intake tract. Is this normal? my teacher says he thinks it is excessive blowby coming in the pcv. I thought some should be normal tho?
It's normal, especially if you have a lot miles on it.
thanks, going to do a compression test on her tomorrow, for some reason my diesel teacher thinks my compression is so low thats why it is having bad cold starts. ill probably sleep a little better tonite lol
Could be glow plugs too or the GPR
ya had a few bad gp's, and i am not getting power to the plugs. I am starting to diagnose that tomorrow at school
Yea probably the GPR. If it does turn out to be that, you can get the Stancor relay that will last longer and heat up the glow plugs better, hotter, and longer. Don't remember the part number but it's in the write ups here.
thanks a lot i printed out NCHornets quied on hot to test the relay so i will tackle that today
Okay glad you got my write up, but GP's and GPR have nothing to do with oil in your intake, that is totally normal and doing the CCV mod will cure this. I recommend doing it on every PSD!! Here is a link any ? just PM me.
CCV Mod Using the Stancor relay is a must and a huge improvement over the stock relay, it will get more power to the plugs but it will not extend the time the power is delivered as stated above. The time the gp's are is controlled by the PCM not the GPR. Just wanted to clear up a few things. NCH |
![]() Man I was tryin to be all smart and it back fired on me
