05-07 Dash in a late 99...
Is it possible? Is it easy? Any mods? Is there a step by step here anywhere?
There is a guy who has done it here but i don't know about the write up.
As far as easy goes? I doubt it |
Several have attempted this but most gave up, there are just to many differences between the two.
NCH |
The dash panels bolt right up actually. However you cant get the cluster to work. The 7.3 PCM doesnt support the 05 up cluster.
Those that have done it and there are several just use the 7.3 cluster with the 05 up panels |
the cluster wont work so youll have to use your old one. everything else lines right up. ALso youll have to splice some connectors here and there.
Does anyone know if you can get TowCommand to work if you do an 07 dash swap and use the original cluster?
