Low boost code. Where would YOU check - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-16-2009, 06:08 PM Thread Starter
E'sStrokr01's Avatar
Question Low boost code. Where would YOU check
Where are the first places You'd check? I don't have the actual code in front of me but I'll get it if needed. Truck DOES feel down on power somewhat. It's strong like a 7.3 should be I guess, but it DOES feel kinda down on power. Fuel mileage isn't all that great either. I'm thinkin' if the boost is up where it needs to be then the mileage might go up some too???
Thanks
E'sStrokr01 is offline
post #2 of 6 Old 11-16-2009, 06:44 PM
jesilvas's Avatar
Quoted: 3 Post(s)
Exactly. Check for boost leaks or exhaust leaks.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 6 Old 11-17-2009, 07:25 AM Thread Starter
Exclamation
No. That was my question.
WHERE are good places to check? Anything specifically known to cause a low boost code to be triggered?
post #4 of 6 Old 11-17-2009, 07:53 AM
jesilvas's Avatar
Quoted: 3 Post(s)
My bad. All the blue boots in between the compressor side of the turbo and the heads on the motor where the orange boots are.
If there is soot around the headers or firewall where the up pipes are, then there is an exhaust leak.
Check the boots on the end of the red tubes and also the boots on the bottom of the pink outline, the spider.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #5 of 6 Old 11-17-2009, 08:00 AM Thread Starter
That's a nice illustration. Thank You.
So, when I check, will there be an obvious pressure of air that I'll feel right away and that I'll know about right away?
post #6 of 6 Old 11-17-2009, 08:21 AM
jesilvas's Avatar
Quoted: 3 Post(s)
No cause with it not under a load it won't boost much at all. You just have to make sure the boots are clamped on tight, are all the way on, make sure there are no tears.
4R100, 2wd
330,000 + miles
jesilvas is offline
