Back up Lights - Ford Powerstroke Diesel Forum
Old 11-15-2009, 04:28 PM
Back up Lights
I would like to know if there is another backup light that will fit. I installed strobe lights. I went to put them in the backup light but they hit the light so I would like to know if anyone knows of a smaller light that will work in there.
Old 11-15-2009, 05:05 PM
Send a message via AIM to joeniel
Subscribed
Would also like to know, my strobe hits the bulb, but neither have blown.. yet
Old 11-15-2009, 06:48 PM
Just install the strobe in the back up light bulb spot... then install some aftermarket back up lights..
Old 11-16-2009, 03:48 AM
I could do that never even thought of it. I have light to install guess I have to get on them
Old 11-16-2009, 09:40 AM
Well I thought of doing that and I already have four other rear facing 55w lights.. but when I go for inspection, wont I fail for not having the reverse lights in?
Old 11-16-2009, 09:44 AM
shaking things up
i think your other lights will count if they come on when the truck if placed in R
Old 11-16-2009, 09:46 AM
Does the law in Mass say you have to have bulbs in there or just that you have to have back up lights?
Old 11-16-2009, 04:56 PM
Well, I searched google and had no luck finding the law. The lights dont come on tho when I put it in R, only by a toggle switch. Anyone know how I could make them come on when I put it in R, but not draw the power from the R circuit, and still be able to switch them on whenever I want? Sorry for the complicated question (or simple to some idno).. doesnt hurt to ask..
Old 11-16-2009, 05:17 PM
You need a ON-OFF-ON switch. You will have three connections on the switch, connect one to the reverse wire, one to a 12v source and the common to a relay powering the lights. The relay will get its power from wherever you connect it. The ON positions would be either a manual on from the 12v source, or from the reverse wire. Optionally, you could use a ON-ON switch, but the the lights would either be manually on or switched from the reverse wire with no off setting.
Old 11-16-2009, 06:34 PM
