Location of the wastegate solenoid - Ford Powerstroke Diesel Forum
Old 11-14-2009, 05:53 PM
Question Location of the wastegate solenoid
Can anyone provide the exact location of the wastegate solenoid on an 01' F-250??? I have a wastegate solenoid fault code that I need to look into
Thanks in advance
Old 11-15-2009, 09:35 AM
Question
It's not a trick question........Really, it's not.
I just need the location. I'd look it up if I had a parts microfiche but we all know that none are available.
Old 11-15-2009, 09:47 AM
Im pretty sure its on the turbo. Look at your turbo and there is a red line that goes to and I would think that is it.
Old 11-15-2009, 09:55 AM
<<---"Shadow"---
Im not aware of any wastegate solenoid on your turbo. I thought the wastegate was controlled by the pressure you have it set at by adjusting the the arm in or out.
Old 11-15-2009, 10:03 AM
Shane your right I was just trying to give him a clue where the wastegate was.
Old 11-15-2009, 10:46 AM
Thanks guys. So, where do I begin for code 1690? That code states wastegate solenoid fault????
Old 11-15-2009, 10:56 AM
On the turbo is the wastegate actuator. Follow the red line to the solenoid mounted on the intake spider.
Old 11-15-2009, 11:32 AM
RPM, if the solenoid is bad, could that be causing a low boost condition as well????
Is it hard to change the solenoid out? Expensive?
Thanks
Old 11-15-2009, 11:34 AM
I've never heard of one going bad, but dont rule it out. Let me see if I can find anything on the price and all for ya. Gimme a few.
Old 11-15-2009, 11:37 AM
Wastegate solenoid - Diesel Forum - The Diesel Stop.com
almost halfway down the page is a pic of it. Not sure on the price yet.
