Stacking chips
I was wondering if anyone had any info on stacking chips what brand to stack an any other info i am stacking on top of a Bullydog 150 hp Thanks
no you can't stack Chips. whatever you "stack" last is what you will be running programing wise
you cannot "stack" at all on obs trucks. if you load a program and then plug a chip in, the chip will over ride the programer...however you can do a 10k or similar mod and use a chip/programer with that...hope that helps a little(thats all asuming ur truck is 94-7)
If it has a 7.3L in it 94-03 you can't stack chips.
Welcome to the forum Slade, It wouldn't hurt to fill out your sig, so when you ask a question, the people trying to answer will be able to answer based on your truck, and the mods you already have. And pop into introductions and meet the rest of the folks. Have fun on the site, and don't be afraid to jump in if you have comments and suggestions.
Gord. |
Well edge told me i could stack the juice module on it an i went to DFUSER.com - Performance Diesel Products and Parts an they have some products i can stack
i believe u can stack edge juice w/attitude with an evolution or EZ...(sry for some reason i thought u were talkin about an older truck)
Your question was probably misunderstood, you asked if you can stack chips, not if you could add a module to a chip. A chip goes into the computer body, A programer changes the computer parameters through the OBD2 port and modules are as a rule, little boxes that are installed under the hood to change fuel pressure, such as 10k and 18 k mods. You can not stack a chip and a programer together, you can stack a chip OR a programer with a module, but you have to be careful. If you have a good chip, such as a DP tuner or a Twildman, the fuel pressure, trans shifts, line pressure, tc locup point are already taken into account, and adding the wrong, or in some cases any module, will not help at all or could damage something. Hope that clears it up a little for you.
Gord. |
Very well said Gord
Well thank you ( bowing to the audiance ) hahaha.
Gord. |
