Exciting
Not an exciting topic but if you guys can help id appreciate it. My AC and heat stopped blowing air through my vents....its only blowing through the defrost. Is there a seperate blower motor (fuse) for the vents or is there a vacuum line problem ? Its getting hot here in the desert and my 2 yr olds getting CRANKY when she rides with me! Thanks for the help.
Look under the driverside of the dash. You will see a vaccume solonoid there. Make sure the hose is connected. If it is, try moving the selector and see if the solonoid is working.
Ill give it a try in the morning, hopefully its something that easy.. thanks.
seen it a bunch of times before....you have no vacume. There is a vacume pump (electric) by the vacume resevour on the passanger side of the engine compartment. First check all your fuses, then check for power to the pump...if all check out and the pump doesnt come on, replace the electric pump.....
You guys are toooo fast hahaha.
Gord. |
he could also jump the low fluid relay to see if he just need more fluid, because it will do the same thing.
