Old 11-06-2009, 01:56 PM
2000_f350 2000_f350 is offline
trans temp between 140 nd 150?
Is this to low? It wont get pash 150. It's on an autometer gauge and I shot the side of the case and it says 145. What do you think? Is it to low?
Old 11-06-2009, 01:59 PM
taylorking taylorking is online now
Send a message via AIM to taylorking Send a message via Yahoo to taylorking
No it's just right
Old 11-06-2009, 02:15 PM
SuperCrutyPS SuperCrutyPS is offline
When you checked the temp of the tranny, how long have you had it running? Pulling a load? Normal driving or pushing it?
This time of year my tranny doesn't run very warm either.
Old 11-06-2009, 02:23 PM
I ran around for abnout an hour and a half. 3 or 4 WOT runs into OD.
Old 11-06-2009, 02:35 PM
tubular031 tubular031 is offline
I usually run 60 to 80 above the outside temp or 130, which ever is higher. I have a 6.0 cooler installed on mine. the 130 # is the temp at which the bypass opens and closes. if less then 130 the cooler is bypassed.
