Old 11-03-2009, 11:36 AM
3adam12 3adam12 is offline
Driveshaft Angle
I just completed a 4" lift on my '02. My question is this: Should the driveshaft be as straight as possible, or should there be an angle in it? As of right now, w/o any shims, it has a pretty decent angle in it. I'm guessing that if I can get enough shims tucked in there, that it will get rid of the small amount of take off vibration I'm getting. It is not axle wrap, as I have a 5" springs in the rear, no blocks, so that should have gotten rid of any possible axle wrap. Again, driveshaft angle suggestions?
All input welcome, thanks.
Old 11-03-2009, 01:09 PM
layson layson is offline
You can still have axle wrap with springs or blocks...
Shims are easy to install and probably would be an easy fix for your shudder during take off. The straighter it is the better off you will be...
Old 11-03-2009, 01:38 PM
Southpaw Southpaw is offline
1/20/2013
I agree with all that ^.
Axle wrap is still possible, straighter is better, I would shim it as straight as you could get it. I did when I put a 4" in my 02.
Old 11-05-2009, 04:38 PM
5 shims later and the bounce was cut by 3/4. 7 shims later and the bounce is pretty much non-exsistant and only a small bounce can be felt at take off, IF you are paying attention. HUGE differance compared to the one shim that was on it in the beginning. Striaghter was for sure better. Thanks guys.
Old 11-05-2009, 04:44 PM
RJM06590 RJM06590 is offline
Built Not Bought
wait where do the shims go??
Old 11-05-2009, 04:49 PM
strokin_early_99 strokin_early_99 is offline
John Wood Nut Swinger
I shimmed my carrier bearing 1" down with my 4" lift and it got rid of all the vibration. I did not change the angle of my axle, it was left stock.
Old 11-05-2009, 05:01 PM
Built Not Bought
i don have a carrier bearing
Old 11-05-2009, 06:18 PM
Darn short buses........LOL.......My bad...
Old 11-05-2009, 07:03 PM
1/20/2013
7 shims?
How thick are your shims just out of curiosity.
I used two 3/8" shims on my carrier bearing when I did my 4"
Old 11-07-2009, 12:51 PM
Built Not Bought
lol its okay jw if my angles can be adjusted?
