- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
Does anyone know what I should look for?
Driving along check engine light comes on then engine looses power , sounds like it is runnung on four cyls. Wait a little while restart runs ok for about 45 seconds to a minute and then goes back to four cyl. mode. Checked fuel filter ,tubes on turbo , all fluids any ideas ????? |
| Sponsored Links |
pull both valve covers....there is a good chance that one of the harnesses under there is partially disconnected from the valve cover.......after the cover is off, look at it and see if it has backed off beyond the clip that is supposed to hold it in place....if it has, replace the under valve cover harnesses.........also, a note.....do NOT remove the baffle that is attatched to the drivers side valve cover....take that one bolt that it blocks you from getting a socket on....take it out with a wrench........Marc
Gentlemen, I have just finished pulling the left side valve cover and the connection on this side did not appear to be loose and definately not out of the clip. I will start on the other side the next time I can get out to the garage. I work a lot of hours and have horses (the reason I have the truck) thank you for your input |
good luck with that...i suspect marks right...rough idle and check engine light seems like a valve issue...
wes |
| Sponsored Links |
