Cigarette plug-in versus Aux Power point - Ford Powerstroke Diesel Forum
post #1 of 13 Old 10-29-2009, 10:14 AM Thread Starter
In Operator Manual, Ford says to NOT plug accessories into cigarette lighter, instead us the Auxiliary Power Point (12VDC).
Do you know why?
They seem to work the same for me.
mas360 is offline
post #2 of 13 Old 10-29-2009, 03:17 PM
if I had to guess the wires going to the lighter are a lighter gauge and rated only for the use of the lighter. Devices plugged into the auxilary power plug could use more amperage and the wires are probably heavier gauge wire to handle it. This is just a guess though. Other than that 12V is 12V so unless what ever you plug in pulls a ton of amperage it'll most likely work fine.
'96 F-250 Extended Cab, long box 4X4, 4" lift, 35" tires
Injectors, Intercooler install kit-GTS Motorsports
Crower rods, H11 Head studs, Cam, Chip Diesel Innovations
Gen II HPOP, chip-Swamp's Diesel
Chip Live Tuned from Power Hungry
Current Chip Tuned by me!
Transmission BTS
custom turbo kit with HX40.
12.683@105.65 in 1/4 mi!
466hp #2 only
805hp NČO
Yeah I can keep up!
gtspowerstroke is offline
post #3 of 13 Old 10-30-2009, 07:03 AM
Powerstroke Junkie
NCHornet's Avatar
IIRC these work off the same fuse, so if that is the case, why should it matter?
NCH
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #4 of 13 Old 10-30-2009, 12:21 PM
Like I said the only thing I could think of is if the gauge of wire is heavier on one vs the other to handle a heavier load.
Transmission BTS
466hp #2 only
805hp NČO
Yeah I can keep up!
post #5 of 13 Old 10-30-2009, 12:50 PM
Maybe, but I would think the cigarette outlet would have bigger wire... the cig lighter draws quite a bit.
My guess? When you start using things other than the cigarette lighter, you could potentially damage the parts inside the cig plug. IE: the stuff that holds the lighter, and lets it automatically pop out.
All I know is my cigarette plug in is a little 'loose' compared to the auxiliary port. I use both to plug things in. GPS in aux and phone charger in cig.
Will
2001 F250 CCSB Lariat 4X4
7.3 PSD, 4R100
wsigo is offline
post #6 of 13 Old 10-30-2009, 12:54 PM
bottomsup's Avatar
Hmm, the ciggie lighter it self draws around 10 amps so maybe the plug style is a little different.
2002 7.3 4x4 AUTO
104,xxx miles
DIY AEM intake
Zoodad mod
foil delete
triple pod
php chip
4" turbo back straight pipe
2 1/2" leveling kit
jwvb
bottomsup is offline
post #7 of 13 Old 10-30-2009, 02:41 PM
01excursion7.3's Avatar
Some car chargers for phones and other devices are a little different design, and need the power port vs the cig adapter. I had a inverter that would work in the power port and not in the cig lighter. Also has a car charger for a cell phone that also need the power port.
2001 excursion 4x4, 4" Magnaflow SS exhaust, AEM Brute Force intake, 05 conversion, 6k HID's, after market tail lights, and thats it for now. More to come..
Maine Turbo Diesels
01excursion7.3 is offline
post #8 of 13 Old 10-30-2009, 02:49 PM Thread Starter
I just plugged my power converter into the power port and no power....
But it works when plugged into the cig lighter....
May be something is wrong with the power port. I have to check with manual to see if perhaps a fuse is missing.
mas360 is offline
post #9 of 13 Old 10-31-2009, 08:37 AM
If the cig lighter gets used to light cigs, then it makes the contact points dirty. This causes a "not so good" connection. While this is fine for a metal lighter, putting a plastic plug into this port could cause overheating, and possible fires (don't ask how I found this out).
It involves a now useless mustang. Anyone need fresh burnt seats?
jcbones is offline
post #10 of 13 Old 10-31-2009, 08:47 AM
Joel's Avatar
Quoted: 10 Post(s)
I hate having wires dangling all over my dash, so I "installed" a dual power point thing inside the center console and robbed the power for it from the power seat wire.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
