i could use some advise... - Ford Powerstroke Diesel Forum
Old 03-11-2007, 11:39 AM
ok so im pretty sure my tranny is hanging on a thread.... when i get on it on the 100hp setting it will shift then it wil hesitate for a little bit then just slam into gear and jurk the whole truck pretty bad..... and ideas..... o and how hard is it to change a pedal assembly cuz i was at the lake yesterday and driving perfectly normal and all of a sudden my gas pedal wouldnt work and stepped on it a couple times and then it was back...... would i be getting any codes for faulty pedal......
Old 03-11-2007, 03:59 PM
duct tape & zip ties
You can get a code from a faulty pedal switch yes. As for your tranny I recommend taking it to AAMCO.com - Home (Transmission Repair, Transmission Service by Aamco. Car Repairs & More) the home of transmission problems. I have had good luck with this company on alot of tranny issues. Plus they have a warranty and they are nationwide.
Old 03-11-2007, 04:42 PM
did u experience anything that i have described
Old 03-11-2007, 04:43 PM
and does that sound like my pedal essembly isgoing out..... i have 110000 on my truck
Old 03-11-2007, 05:57 PM
I never experinced any problems with the pedal switch. But the tranny yeah I had that problem hard shifting into certain gears, eventually i needed to get a rebuild.
Old 03-12-2007, 12:00 AM
did you go with the stock rebuild or the beefed up rebuild..... what was the cost and.... how do u like it
Old 03-12-2007, 10:23 AM
average cost for a solid upgraded rebuild is around 2,200 from aamco, including labor and 12,000 mile one year warranty. I do like my trans I have had no problems with it yet. I still have a bit of the warranty on it so if I do have problems I can take it back before the warranty is up.
Old 03-12-2007, 11:08 AM
Does the tranny do the same in all the settings on the chip, or just the one setting? Sounds like the tc is locking up funny on it, and if it's just on that one setting, it could be the programing for the trans on the chip.
Gord.
Old 03-12-2007, 11:42 AM
ya it is only in the 100hp setting........ im leaving right now so ill run it a little bit and see if thats a good answer
Old 03-12-2007, 11:57 AM
International Threat
Ask purduefarmboy for his fix for this...
