need frame help
k the frame is bent about a foot back from the bumper at a 45 degree angle, yall know any good ways to get it straight (does not have to be perfectly straight, will only be used for offroad mud bog competions )
any one out there that can help
Moved this over here for you, should get more action, good luck BN.
Gord. |
If you end up needing a frame, I have one: 99 F350 CC long box.
Well since it is for mud bog purpose only, heat, comealong, a tree and a chain. Heat the frame where it is bent, hook a chain around a tree, hook the comealong to the chain and the frame. Use the comealong to pull on the frame while your heating it up with a set of torches. It will bend back straight. But how do you know that the rest of the frame is not bent. I would not be caught riding around in that truck even if it is in the mud only.
Heat
Heat Heat! Oh and a big pipe wrench, maybe a 48"!
haha i thought i jerry rigged stuff but i think its a little more serious than bending it back with a come along here are some pics of the frame and where its bent
here are some more pics
Ah,
You can do it.
Bigcountry is right on the money. I've used the old come-along, tree, torch method and it usually works. If you keep dragging the truck through the mud with out getting a bend then the poor boy portapower works too. Just chain the frame to a tree at just behind the bend and use a highlift jack to push it over. A BFH will help with that pooched out section. It's not a bad idea to weld a little plate over the area you heated and bent to stiffen it back up a bit. Careful with that come-along cable and don't forget the six pack(s)!
