Map Sensor - Ford Powerstroke Diesel Forum
Old 03-08-2007, 02:27 PM
Map Sensor
Just Wondering About How Much Im Going To Have To Shell Out For A New Map Sensor And The Best Placeto Get One.
Old 03-08-2007, 04:20 PM
Desert Shield/Storm Vet
What year is your truck is it a 7.3 or 6.0? Your probobly looking at 60-80 bucks.
Old 03-08-2007, 05:23 PM
Yeah I Guess That Info Would Be Pretty Helpful Sorry Bout That Its A 2000 7.3 Where Is The Best Place On The Net To Get One
Old 03-08-2007, 05:29 PM
powerstrokeshop.com i think is about the cheapest place for actual ford parts...dont know if napa or autozone or anything carries map sensors for these trucks.....
just out of curiousity...what makes you think your map sensor is bad? it does happen but its not all that common...
Old 03-08-2007, 05:35 PM
I Had It Hooked Up To A Diagnostics/code Reader And It Said That No/low Boost Was Sensed And The Map Sensor Read No Volts
Old 03-08-2007, 05:39 PM
The Problem I Have Been Having Is That When I Get On The Throttle It Runs Fine Up Till About 2200 Rpms Then It Falls On Its Face Like Its Defueling
Old 03-08-2007, 07:30 PM
You could try ebay heres a link to one. eBay Motors: FORD SUPERDUTY F-SERIES PICKUP E- VAN MAP SENSOR (item 140094704612 end time Mar-15-07 19:16:08 PDT)
Old 03-09-2007, 03:13 AM
Here is a link to powerstrokeshop.comPowerstrokeshop.com I believe he is a ford dealer also The link isn't working but you can do the search once you get there.
Old 03-09-2007, 05:16 PM
Thanks For All The Help Think Ill Try Map Sensor
