Ok first post, so I have been reading post in this forum on upgrades on my headlights, and not finding exact what I'm looking for. I have a 2000 f250 and headlights are yellow cant see at night, so I have upgrade to the 9007 headlight bulbs, better not good. So after reading some forums I'm thinking of a couple conversions, 1) upgrade to 2003-04 headlights with there clear lense with the 9007 bulb, a straight direct change out housing. Has anybody done this, How was the light difference. 2) change to 2005-07 headlight change, but theres cutting and modification to do this and wiring plug change??? 3) after market asco headlight conversion seem straight change, no cutting and modifications any different than just converting to 03-04 headlight???. I want to upgrade with out cutting, looking for best and easiest upgrade ha ha. Main question is has anybody done the 03-04 headlight with bulbs and how was the lighting difference???
- I used regular 9007 bulbs and the output was better because the lens are clear. I later decided to upgrade to SilverStar 9007 bulbs. To me, the light output is much better than stock bulbs.
Ok. Yes I was looking at a couple different sets on there but not sure what the difference is between the 2 offered. I'll have to call.
Is that where you got yours from?
I ended up going with 1A auto, complete set with parking lamps for $105, lifetime warrantee! Piece of mind when and if they ever do fade or get crappy, then it's worth the extra $10-15 to me. They sell good stuff so I'm a repeat customer now.
I didn't want to start grinding away on my header panel and make this a seamless transition along with the updated '05 grille so the 1A parts will hopefully fit perfectly.
eBay parts were slightly cheaper but when there's a problem I'm not wanting to track down a vendor that can't be bothered.
When I do my front end conversion im going to use the 05+ header panel, its a bolt in swap and they are cheap. You can get the header panel, grille, and lights for like $150.
Never had a minutes trouble with eBay parts have thousands of transactions on my account.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
