Old 10-18-2009, 10:22 AM
Arrow trany temps
ok, im from the central texas area and i was wonderin what trany temps on 250s should look like, i just got a gauge on mine and i knew it would run hotter than my old 150 but what is norm that everyone sees, and what is the point of were u start burning stuff up, im jw, thanks
Old 10-18-2009, 10:37 AM
A ballpark temp would be, outside temp + 100 degrees is a place to start. Depending on your cooler setups.
Old 10-18-2009, 10:42 AM
Heavy Equipment 911
With out knowing your ambiant temp its hard to say. Go record the temp and the drive it around tell its at operating temp and let us know what you have and then we cans say if its where it needs to be. To hot would be anything in the 300's to high 200's although I dont like my truck going over 200.
Old 10-18-2009, 10:48 AM
Peggy Bundy - Cougar
That is too hot, if you are towing thats another story, but that temp is too high.... I dont like anything over 200 and the jersey summers dont even set me over that and they can be brutal with the heat and humidity. Texas is the same but it still shouldnt be getting that high.
Old 10-18-2009, 10:52 AM
shes been runnin around 200 or so, depending if im on the highway or not , but it seems to slowly creep up untill i get to were im going no matter what, although the trany dosent even have 300 miles on it. i lost it tues night and got it back friday. Is there a break in time on these lol
Old 10-18-2009, 10:53 AM
Shouldnt be, check the cooler lines at the transmission for the check valve or replace the cooler, it may be partially clogged.
Old 10-18-2009, 10:59 AM
check valve??and were can you get coolers from , ive wanted to get the stock peace of **** out of there but my trany put a kink in that plan lol
Heavy Equipment 911
Mine ran hotter after I had it rebuilt. Did they replace your cooler. No reputable shop would rebuild a trans and leave the original cooler in. The design makes them extremely hard to clean out.
Old 10-18-2009, 11:00 AM
Heavy Equipment 911
Shop around for a 6.0 cooler if you can find one. There is no aftermarket cooler that can compete with it.
Old 10-18-2009, 11:08 AM
I fully agree.
As camptoboat says, "Depending on your cooler setups." The stock cooler is only 9 rows. You can put in a 6.0L cooler which is 31 rows. It bolts in the same place, you have to get some 1/2" hose, some adapters to go from 1/2" to 3/8" line (stock truck line). After I installed mine, the temps dropped. On 100* degree days here, the tranny runs about 165-180*. On days in the winter, where temps are in the 30-40s, the tranny runs just above 100*. Very helpful when pulling my 5th wheel. In the summer I could easily peg my 250* gauge witht the stock cooler. After I changed the cooler, temps don't get about 180-195*.
Something for you to consider.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.2
