Trailer plug accessory power F-350 7.3 2001 - Ford Powerstroke Diesel Forum
Old 03-07-2007, 10:25 PM
Send a message via Skype™ to Dkahnjob
My truck has the factory trailer wiring plug, but there is no power to the aux power terminal. Is there a fuse or circuit breaker somewhere? It appears to be the orange wire that feeds the terminal, I checked all of the fuses in the fuse box under the hood on the drivers side, all were ok. I use that power source for the electric jack on my boat trailer.
David
Old 03-08-2007, 04:09 AM
Send a message via AIM to purduefarmboy460
Might just have to run a new wire back there if you aren't having any luck, how far up can you trace the factory wire?
Old 03-08-2007, 09:26 AM
I only looked at the plug and saw that there was an orange wire going from the harness into the plug. By that time is was 11pm and I quit. Will look some more tonight.
David
Old 03-08-2007, 03:53 PM
BIG TRUCK, SMALL DRIVER
Read the owners manual. I think you have to add a fuse to make it work, just like the trailer brakes. It should be one under the hood in the power distribution box.
Old 03-08-2007, 04:34 PM
My truck didn't come with the owners manual, but I will check the fuse box.
Thanks.
David
Old 03-08-2007, 06:09 PM
Smile Hi Guy's
I have a manual for my 99 f-350 and it shows it should have a 30 amp maxi fuse. The location in the box shows number 16. It is the trailer tow battery charge wire. Hope this helps. I know when I wired my travel trailer plug mine didn't work either. I replaced the fuse and things were good to go.Hope this helps. Just remember my manual was for a 99 just be cautious.
99 Red Stroker
Old 03-08-2007, 08:28 PM
99 Red Stroker
I checked the fuse and it was ok, then I turned on the ignition, and it worked.
I feel pretty stupid! But on my Chevy that terminal is hot with the key off.
Thanks for the help. All is good now.
David
