Newby's question? - Ford Powerstroke Diesel Forum
Old 03-07-2007, 06:37 PM
Cool Newby's question?
When i start to drive my 2000 F250 7.3. should i switch the overdrive to off and then at about 2000 RPMs turn it on? I've read different stories about wearing out trans. I also noticed today that my truck doesn't seem to rev. above 2100 RPMs. I 'll check it soon. How can i check to see it computer has been modified with a tuner or something? I just got it w/80000 miles and don't know about its previous life . It has air bags in rear springs and an energizer for trailer brakes. ( i think). It would appear that the previous owner has done mods to truck. Thanks for any help.
Old 03-07-2007, 06:39 PM
The Fat Mod
You should be fine to leave the OD on. The only time I would turn it off is when I was pulling, or going down a long grade. If you get on it, does your tranny shift higher than 2100?
Old 03-07-2007, 06:48 PM
I'd like to turn it off when starting to roll. (Its is more responsive) And turn it on when i'm moving 45 + MPH. While i'm starting from stop, i have it off and truck gets to 2000, i switch it on, then RPM drop to 1300sh. But will all this shifting wear down my trans? I'll try to drive with OD off and see how high it revs. thanks again.
Old 03-07-2007, 06:51 PM
The Fat Mod
You can shift it how ever you want to. Its your truck But, the over drive is in there to keep those RPMs lower and save on diesel. Its also easier on your truck to drive it at lower RPM. Anytime you put more movement on a part, the more use it gets, so the sooner it may go out. but, if you keep the fluids good in it, you should not have too much trouble.
Old 03-07-2007, 06:56 PM
Send a message via AIM to 99Smokin73Stroker Send a message via Yahoo to 99Smokin73Stroker
Most people don't seem to mess with OD unless they are towing
Old 03-07-2007, 07:45 PM
I use mine only when towing or if i am going up a grad with out a trailer and need to get around somebody i will use it.
Old 03-08-2007, 11:57 AM
Only turn it off when towing, leave it alone all the other time and she will be fine.
