Old 10-15-2009, 04:25 PM
chvyrkr81 chvyrkr81 is online now
Wait what did I click?
Piston Rod info
Anybody ever seen this?
Is it acurate?
I've heard of guys breakin down motors made after 01 and finding forged rods but...
Here is the engine serial number break down for the forged and powdered connecting rods. Check you engine serial number on the valve cover build sticker or you need to look at the block where the oil cooler is bolted to it .
Start of production thru 1425746 are Forged Rods
1425747 thru 1440712 are Powdered Rods
1446713 thru 1498318 are Forged Rods
1498319 thru final production run are all powdered
Old 10-15-2009, 04:45 PM
jbeasts10 jbeasts10 is offline
Lifetime Premium Member
I looked through the inspection hole on mine..Not forged here
Old 10-15-2009, 04:48 PM
Do you know your motor SN?
I'm curious to see if this list matches up.
Old 10-15-2009, 06:29 PM
I checked it against the # and yes it confirmed it.I was still curious and had to look though.
Old 10-15-2009, 06:35 PM
jamstoyz jamstoyz is offline
so i guess the forged rods would be better than powdered huh?
Old 10-15-2009, 06:40 PM
With proper tuning forged is holding over 600.
PMR is only "safe" for around 400.
Old 10-16-2009, 01:29 PM
my # is 1847089 which isnt on the list
Old 10-16-2009, 02:13 PM
Yeah this is 7.3 specific.
All 6.0's come with PMR's. I don't know enough about the 6.0 to do anything but speculate, but either the PMR's in the 6.0's are made stronger, or the smaller diameter piston doesn't create a problem.
Old 10-16-2009, 03:14 PM
POWERED SPARKLESS POWERED SPARKLESS is offline
<---Burger Anyone??
I've seen this list a few times now. Can't say how it stands up, best of luck to ya'll 7.3 cats.
Old 10-16-2009, 03:37 PM
Yeah, I'd kinda like a few guys that KNOW they have one or the other to join in with their motor SN and see if the list matches up.
I'm especially curious about the motors where the numbers go back to forged after bein PMR for 50,000 or so.
